No heat from heater, fan works
2004 CHRYSLER PACIFICA
200,000 MILES
LEE ANN MINGO
My digital display for the A/C and heater went blank then shortly the heater only puts out cold air. Checked antifreeze and fuses. The fan works fine just not any heat.
Aug 13, 2018 at 8:22 PM
Please check the heater hoses to make sure they are hot going into and out of the fire wall if so it sounds like a temperature blend door actuator is not working right. Here is a guide to show you what you are in for when doing the job and diagrams below to show you how it will be for your car:
Aug 16, 2018 at 1:37 PM
