No heat Climatronic code is 4FA and 538
2004 VOLKSWAGEN PASSAT
160,000 MILES • 2.8L • V6 • FWD • AUTOMATIC
COTYG
  • 4 POSTS
My heater worked last year fine we let the car sit for about three months and during the summer. the AC did not blow out cold air. the compressor is bad but the heater was still working, but now all I get coming out of all the vents is cool air. it feels like the air from the outside temperature really so I did the climatronic system test and got codes 4FA and 538. I also did the "reset" test where it cycles through the whole climatronic system to test everything to make sure the code was right and sure enough it popped up again 4FA. I can hear the motor clicking to open/close the flap when I switch the temperature from cold to heat but still only get cold air coming through vents. I know it is really hard to replace the motor that controls these flaps so is there anything else I can do? I have a three year old and this is our only car he already had to deal with no AC all summer (cannot afford $400.00 for parts and $300.00 in labor) with the windows always down. but, I cannot let my little guy freeze all winter. please help I need to fix ASAP! Thank you in advance!
Sep 28, 2017 at 7:20 AM
Yes, it is going to be cold winter we better get this fixed up. I does sound like you have a blend door actuator that is out which would be the ticking you are hearing which is failing to move the internal door for the temperature control.
Here is a guide to give you an idea of what I am talking about:
Below are some diagrams of what it will take on your car.
See if this is where the ticking is coming from. Also, if you can take a video with your phone of the noise and upload it here it would help us figure the problem out.
Please let us know what you find.
Sep 29, 2017 at 9:37 AM
COTYG
  • 4 POSTS
OK my fiance has the car all today so I can't post a video tell later tonight or first thing in the morning thank you for the reply o I also wanted to ask if I take off the glove department would I be able to manually close the flap so we could get heat or is that not possible I read u can see the flap with the glove box off so that's why I ask again thank you
Oct 3, 2017 at 2:27 PM
Yes you can move the air door by hand and then rig it so it doesn't move I can help with that just send pics of the situation.
Oct 4, 2017 at 11:05 AM
COTYG
  • 4 POSTS
I posted the video it's the best I can get let me know if it's good enough
Oct 4, 2017 at 11:33 AM
Yep that helps, it does look like the actuator is out becasue the controller is working correctly. Go ahead and remove the actuator and move the pivot by hand to see if it moves freely. Then we can rig or fix it.
Oct 4, 2017 at 12:42 PM
COTYG
  • 4 POSTS
K will do that first thing in the morning tell u what happens and take pics as well
Oct 5, 2017 at 4:11 PM
