heater is not working?
2002 JEEP LIBERTY
198,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
CANNON1349
  • 861 POSTS
Customer diagnosed vehicle having a stuck thermostat, after replacement the heat was still barely warm. Coolant was brownish color. Also the radiator didn't drain from the petcock, had to pull the lower hose.
Thinking about a new radiator?
Nov 15, 2019 at 6:19 AM
Good afternoon,
Sounds like the system has dirt and debris in the system.
https://www.2carpros.com/articles/car-heater-not-working
I would remove the hoses from the heater core and use a garden hose and flush the core back and forth. Run it until you get a good flow from both directions.
I would also flush the cooling system as well.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Sep 21, 2020 at 10:14 AM
CANNON1349
  • 861 POSTS
I flushed the heater core and radiator with a garden hose and also used some Blue Devil and let it circulate and replaced with fresh coolant. The car gets hot in the driveway but after 10 minutes the heat goes cold. When I park it the heat will return in a few minutes. Think the new thermostat is stuck or what?
I doubt it.
Has the engine ever overheated?
The additive you used is not good. It clogs up the passages in the radiator and the heater core.
Are both hoses hot at the firewall when it does not have heat?
CANNON1349
  • 861 POSTS
Engine has not overheated. Yes, both hoses get really hot at the firewall. Upper and lower rad hoses also get tight and very hot.
This points directly at the heater core as the failure.
You have hot hoses and heat above idle. You have a clog in the core that slows the circulation.
WARNING:
- ON VEHICLES EQUIPPED WITH AIRBAGS, DISABLE THE AIRBAG SYSTEM BEFORE ATTEMPTING ANY STEERING WHEEL, STEERING COLUMN, OR INSTRUMENT PANEL COMPONENT DIAGNOSIS OR SERVICE. DISCONNECT AND ISOLATE THE BATTERY NEGATIVE (GROUND) CABLE, THEN WAIT TWO MINUTES FOR THE AIRBAG SYSTEM CAPACITOR TO DISCHARGE BEFORE PERFORMING FURTHER DIAGNOSIS OR SERVICE. THIS IS THE ONLY SURE WAY TO DISABLE THE AIRBAG SYSTEM. FAILURE TO TAKE THE PROPER PRECAUTIONS COULD RESULT IN AN ACCIDENTAL AIRBAG DEPLOYMENT AND POSSIBLE PERSONAL INJURY.
- IF THE VEHICLE IS EQUIPPED WITH AIR CONDITIONING, REVIEW THE WARNINGS AND CAUTIONS IN THE FRONT OF THIS SECTION BEFORE PERFORMING THE FOLLOWING OPERATION. See: Heating and Air Conditioning > Technician Safety Information
1. Remove the HVAC housing. Refer to Housing Assembly HVAC/Service and Repair/Procedures See: Housing Assembly HVAC > Removal and Replacement > HVAC Housing - Removal and Installation
Fig.14 Heater Core Removal/Installation
2. Remove the two heater core retaining screws (if equipped)..
3. Gently push back on two of the heater core retaining tabs and pull up on heater core to remove.
INSTALLATION
WARNING: IF THE VEHICLE IS EQUIPPED WITH AIR CONDITIONING, REVIEW THE WARNINGS AND CAUTIONS IN THE FRONT OF THIS SECTION BEFORE PERFORMING THE FOLLOWING OPERATION. See: Heating and Air Conditioning > Technician Safety Information
1. Install the heater core into the top of the HVAC housing.
2. Push on top of heater core until all for tabs are locked into place.
3. Install the two heater core retainer screws.
4. Install the HVAC housing. Refer to Housing Assembly HVAC/Service and Repair/Procedures
CANNON1349
  • 861 POSTS
Some guys let CLR sit in heater cores for clogs.... how do you feel about that?
I have never used any product that breaks up clogs from rust. You could try doing it again with shop air and a garden hose. I think I would give it a second shot before pulling the trigger on a heater core. These are a pain to replace. I have bad memories doing these.
CANNON1349
  • 861 POSTS
I've already done the garden hose method. Water comes out both ends just fine, clear.
Okay, if both hoses are hot, the blend door is working back and forth, the only thing left is the core itself.
https://www.2carpros.com/articles/replace-heater-core
https://www.youtube.com/watch?v=-xnM-K5A3ow
CANNON1349
  • 861 POSTS
Just humor me. Could it be that the system still isn't bleed correctly? These have those little bleed valves at the upper rad hoses. Maybe I'm doing something wrong.
Those valves are to be opened only when filling the system. The engine cannot be running or it will draw air into the system.
To bleed it, run the engine at 1,200 RPM's with the cap off. Wait until the thermostat opens and you get heat. Monitor the level and keep it full. Once you have good heat, install the cap and return to idle.
CANNON1349
  • 861 POSTS
What about a heater control valve?
There is no heater control valve in the hoses as in the older days. The heat control is handled by an actuator or door that allows heat or shuts it off.
CANNON1349
  • 861 POSTS
Well, I attached two hoses to the core and added some CLR. Which is clear. One bottle is 28 oz and I almost used it up. It's okay to see the green color even though I flushed it before adding right? Since the additive is clear? I'm going to let it sit overnight.
Okay, let us hope it breaks up the dirt and debris in the core.
CANNON1349
  • 861 POSTS
So I flushed the CLR out of the core and here's what happened:
I got the car to get heat, my vent gauge showed 109.8 F, ambient temp today was about 70 F with 100% humidity .I drove it for 5 miles and the temp went down to 90 F, basically feels like slightly warm air. When I parked it at the house, the temperature started climbing again.
Sounds like it worked.
Drive it for a while and see if it gets better and stays at the 109.
CANNON1349
  • 861 POSTS
I'll check the coolant level in the morning and see if itll get hot again. Maybe the ambient temp is making it difficult. The 90 F air really didn't feel too warm but wasn't exactly cold
So you're saying it's normal for the heat to go way up in park and down nearly 20 degrees while driving?
No it's not normal. You still may have some dirt and debris in the core.
CANNON1349
  • 861 POSTS
I heard I might need to bleed the system with the front end lifted. Maybe that could work.
No, that does not need to be done at all. I gave you the bleeding procedure back a few posts.
Did you follow that?
CANNON1349
  • 861 POSTS
Sure did. I suppose there is still debris in the core. But the owners were happy with the warmth vs blowing cold.
Good deal.
MARILYN MILLER
Heater was over to max on the control dial some heat not much. had heater core flushed out twice. no overheating. light does not come on when car starts. the thermostat goes to the middle of the gauge and stays there. Have pulled out the glove box door and listened to hear if the bend door actuator is working and it does. Does my vehicle have a heat control valve on it? the shop that was working on it is stumped as to what is going on. Should I have the thermostat valve replaced anyway?
Jan 21, 2021 at 11:04 AM (Merged)
MARILYN MILLER
Top hose running hot. the bottom hose is running cold that runs to the heater core.
STEVE W.
  • 15,113 POSTS
Sounds like the core is plugged. The Liberty uses a parallel flow design instead of the older single loop. When you flush them you could be pushing water through two of the paths but the rest are blocked. The picture shows the coolant flow and how flushing doesn't really work on that style core.
