Blew a coolant line (the throttle body return line) on the way to work. I removed the plenum and replaced the line, everything back to normal except I have no heat. The car and cooling system are in great condition, the heat has always been good. The interior fans and climate controls are all working as normal, no heat under any conditions (driving/idle). I fully bled the system after repairs, no air pockets remaining. Car not overheating. coolant lines get hot except the ones going to the heater core. Can you assist with a cooling line diagram and a way to test the dccv (heater valve) is there a fuse I can pull to shut off the heater valve, so it goes into bypass mode? I can't get my hand in there. Thank you
Jan 2, 2024 at 6:40 PM
