Went through entire electrical, replace blend door actuator and it works. Replaced thermostat and burped coolant. Car gets to temperature, reservoir full, but no pressure. Replaced cap. No pressure. Top heater core hose hot, bottom hose cold. The small hose from the bleed valve housing in constantly pumping with reservoir cap on or not. So that indicates water pump is turning. But still no pressure in either upper or lower radiator hose. Stumped. Thank you
Dec 28, 2017 at 4:00 PM
