No heat from the heater, the A/C works fine?
2017 FORD EDGE
107,500 MILES • 2.0L • 4 CYL • 4WD • AUTOMATIC
HERBIEC
I replaced the cabin air filter. No heat from the heater, the A/C works fine. Any ideas? Everything worked good before.
Feb 21, 2024 at 10:38 AM
The air temperature door actuator is near the cabin air filter. There is a chance it was disconnected. I attached two pics below. The first one shows the cabin air filter location in relation to the actuator. Pic 2 simply shows the actuator connector.
Check to see if that is loose, disconnected, or damaged in any way. That is what controls the air temp entering the vehicle.
See pics below.
Feb 21, 2024 at 8:09 PM
