No relay. Power from the battery goes to the switch, from the switch to the dimmer switch and out to the high and low filaments in the lights. If you lost all headlights high and low it's more likely either the power isn't getting to the light switch or a bad ground at the other end.
To check, go to the left headlight and pull the connector. Hold it so the connections look like a U and the left terminal is the ground, bottom terminal and right terminals are headlights. Turn on the switch and use a simple test light connected to battery positive, lights on low beam you should have power to one terminal, high to another. No power at any = there is a problem between the dimmer switch and the battery. If you have power, the ground has failed. That is the black wire that goes to the core support on the left side. Use the test light connected to battery positive, does it light when you touch the left terminal in the light socket? If you find no power at the socket, you need to start tracking back through the circuit. Go to the headlamp switch, with it off do you have power at terminal B1? no- bad power feed from the battery to the switch.
Jun 12, 2024 at 11:21 PM
