No gears
2005 FORD KA
71,778 MILES • 1.6L • 2WD • MANUAL
KAREN COLES
Driving along changed gear put fòot on accelerator only revving.
Oct 10, 2019 at 4:47 AM
If the engine is reving while in gear, then your transmission is slipping or has an internal failure.
When you stopped and put it in Park then back to drive, does it still just rev or does it move at this point? Meaning did this happen one time or do you not have any gears at all at this point?
If you don't have any gears then this is either due to a failed transmission pump and you are not getting sufficient pressure to engage the gears or as I said, there is an internal failure that will require a replacement or rebuild. If you have the ability to check for codes, let's start there. That will help us identify if this is just an electrical issue even though I doubt it.
Then we need to check pressure in the transmission to ensure that the pump is operating.
Let me know about this and we can go from there. Thanks
Oct 11, 2019 at 1:31 PM
KAREN COLES
Thank you for your reply, it is with all gears I have had AA home start out and they have said clutch has gone.
I will check the transmission fist before I send it to the garage.
Oct 12, 2019 at 2:21 AM
I am sorry. I just reread your first post and saw this was a manual transmission. I answered you as if it was an automatic.
Since is it a manual I would definitely look at the clutch first. My guess is the throw bearing or slave cylinder has failed.
Oct 12, 2019 at 7:09 PM
KAREN COLES
Thank you.
Oct 13, 2019 at 1:48 AM
You are welcome. Let us know what the end result is because that info will help others now that I gave advice that fits your vehicle. Thanks
Oct 13, 2019 at 11:29 AM
