Good morning,
The oil pressure switch is a built-in bypass for the relay if the relay fails. Disconnect it and see if it starts.
I attached a wiring diagram for you. It is an old diagram but shows the wires and colors. You need to remove the connector for the fuel pump at the tank and test for power when you turn the key on. There will be power for 2 seconds until you crank the engine. Then it should have constant voltage.
There is a primer connector secured to the harness at the relay. Use a jumper wire from the battery positive to the connector. The fuel pump should come on as it is a direct shot to the fuel pump.
Dec 15, 2021 at 4:19 AM
