no fuel pump
1994 FORD CAPRI
95,000 MILES
SHAWN CREECH
No voltage to fuel pump checked fuse its good checked relay its good checked inertia switch its good don't know what else to check no broke wires ether
Apr 24, 2013 at 11:29 AM
JDL
  • 16,098 POSTS
When you first turn on the key, no crank, can you hear the fuel pump run?
Apr 24, 2013 at 11:45 AM
SHAWN CREECH
No car does not run unless u add carb cleaner to throttle body pump not working no voltage to pump
Apr 24, 2013 at 11:47 AM
JDL
  • 16,098 POSTS
Did you check for voltage on both side of inertia switch? That voltage comes from fuel pump relay. Note the diagram.
Apr 24, 2013 at 1:26 PM
JDL
  • 16,098 POSTS
Just to add, the capri I looked at was mercury capri, 1.6L, non turbo.
Apr 24, 2013 at 1:27 PM
