No problem.
If you look below, I highlighted the wires from each injector to the PCM. Each of those wires is to receive a ground path from the PCM. So, all pink wires are power, and the highlighted ones are the ground.
Before you take anything apart on the PCM, I want you to locate the black/white wire on the rear of the engine. That is the primary ground for the PCM. If that fails, it could be the cause. It is identified in the first pic at the very top. I circled and highlighted it.
First, locate the ground on the rear of the engine. These grounds are known to fail. Also, there is a splice in the wire which could fail as well. The easiest thing to do would be to check for continuity to ground via that wire. If there isn't, then we need to find where the open is in the wire.
If the ground is good, then I need you to disconnect the battery and then disconnect the PCM to see if there is corrosion or any damage in the connector.
Let me know what you find.
Jun 27, 2021 at 9:24 PM
