I got it running now. I checked relays even ran jumper from battery to fuel pump one to check ground for pump and to to run it. So I unplugged battery for thirty minutes then reconnected turned key to on for two minutes then turned off and then back to on with fingers on fuel pump relays they both click and car started. So I know with disconnecting battery I reset ECU what causes ECU to trip? And two door locks stopped working also. is this anyway connected or just poor timing?
Dec 27, 2018 at 9:47 AM
