I am getting no fuel from the injectors. New fuel pump (working), new filter, injection control module is good, and i have spark. Fuses are good too. I checked the injectors and one of them is good, the other is bad. Would one bad injector cause there to be no fuel from the good one? I am thinking the fuel line from the filter up to the TBI unit could be clogged. When I removed the old pump it had a lot of gunk in it. Obviously i need to replace the injector that is bad, but that still will not solve the issue, or will it? I have even heard that the distributor is the cause of my issue. See pictures.
Feb 27, 2018 at 10:32 AM
