Note the diagram. You have an oil pressure switch that runs in parallel with fuel pump relay. Once you crank it enough to bring up oil pressure, if the switch is functional and has voltage, the switch closes and the pump will run regardless of relay. At the relay, the green wire with white tracer is voltage for control side of relay. Comes from computer. Just curious, do have spark at the plugs and fuel injector pulse, engine cranking?
You can jump the load side of relay to see if fuel pump will run, the load side is that line with arrowhead. Use a jumper wire, unplug relay, I believe the wire colors are orange and gray. Of course the fuel pump needs voltage and ground, the top wire at pump, in the diagram should be voltage, the bottom wire is ground.
Sep 22, 2017 at 11:54 AM
