My vehicle ran out of gas and now it will not start. I dropped the tank to check the fuel pump. I have checked all the relays, all the fuses, all the grounds cleaned them, yet still not getting fuel or pressure. I originally drained the fuel rail line and it was even worse and then I do not know, but through everything and trying to crank it somehow it almost started and I thought maybe I will just drain the air out again and then I will fix it it will once I did. now again has no pressure not getting pressure I can hear the pump test at the pump. I have read everything. I do not know what the issue is that I did not check. seems like the module I do not think you can connect the wires on that was wrong still no start paying for it and it is just sitting there. It has been about a month. Has funny a crank check the starter the solenoid the only thing I am not 100% positive about is the Navy oil pressure something about four pounds of pressure to even turn over and start. I think my computer is stuck so it is telling it that it has fuel and I do not know how to reset the PCM correctly or if this is something that I might actually just have to take to a dealer and have them manually reenter all the specification codes for my vehicle.
Nov 13, 2016 at 11:09 PM
