I have adapted the GM hydro-boost to the vehicle and cannot get the front brakes to work. New master cylinder, new brake lines, new calipers. I have eliminated the apportioning valve, tried both ports out of the master cylinder, rear brakes work with normal pedal if one port is blocked. If both front and rear are hooked to master, you can pump them up but when you let the pedal up for a bit then it goes back to the floor. But block one port and the rear brakes work with solid pedal. I have bled from top and pressured up from bottom, cannot think it is air. With engine running power assist works as does power steering. With just the front brakes hooked up with one port blocked, same situation, you can pump up to solid pedal, no leaks, but when you let up, pedal returns to the floor.
May 26, 2018 at 7:32 AM
