No forward or reverse gears
2016 ISUZU NPR
40,000 MILES
JOHANN NAUDE
  • 10 POSTS
Drove vehicle stopped at a stop light when i wanted to drive again no forward or reverse gears. Had to tow it in.
Jan 22, 2020 at 5:40 AM
Good morning,
Did you check the fluid level to be sure it is up to the correct level?
https://www.2carpros.com/articles/automatic-transmission-problems
I need more information. Is this the HD?
What engine? Gas or diesel?
Jan 22, 2020 at 6:15 AM
JOHANN NAUDE
  • 10 POSTS
Yes, checked fluid level and fluid nice and clean no smell to it .Checked connections to motors (I think it is motors) nice and clean.
Jan 22, 2020 at 8:34 AM
JOHANN NAUDE
  • 10 POSTS
Sorry guys it's a diesel tiptronic?
Jan 22, 2020 at 8:36 AM
Hello again,
A common issue with these that I have found is the torque converter hub. The torque converter seizes and breaks the hub. That will give you no forward or reverse.
Jan 22, 2020 at 8:43 AM
JOHANN NAUDE
  • 10 POSTS
Thank you makes sense. can hear something engage when i put it in gear. I appreciate your help.Will pull gearbox and let you guys know what i found.
Jan 22, 2020 at 11:15 AM
Sounds like a plan.
You are welcome.
Always glad to help.
Jan 22, 2020 at 11:45 AM
