I suspect the previous owner changed the rotor and maybe the caliper on that side thinking it was the issue. But whenever i opened the bleed bolt on the caliper nothing came out. I opened the 10 mm line where the caliper hose connects to main one and nothing came out when i pressed on the brake. While in the air if i press the brake the wheel doesn't stop, no wonder why it pulls to the right when i brake the whole driving. The last picture us for the caliper from the other side. I can't tell if the caliper is new on the side with the issue, but i tried to press it back i faced resistance and stopped after i pushed it just a bit.
May 23, 2025 at 6:45 AM
