The connector to the coil was loose on number two coil. I replaced new spark plugs and when I disconnect the connector from the coil the connector broke. the engine was starting before I did that, but now it wont start; no firing, no fuel pump coming on. I do not know what could have happened. if the connector wires touch each other will that cause the engine not to fire and fuel pump not working? What all do I need to check to fix the problem? why it not firing and fuel pump not coming on? Please help.
Oct 19, 2016 at 9:35 AM
