No electrical power, will not start
2006 HONDA ODYSSEY
132,000 MILES • 3.6L • 6 CYL • FWD • AUTOMATIC
CHASEBSMITH
Yesterday I noticed that the van had absolutely no power. No lights and would not crank at all when I tried starting. I replaced the battery and still nothing. I first noticed this when I tried unlocking the van with the remote and it would not unlock. I show 12.5 volts coming out and 12.5 volts from the main fuse box. I am guessing a relay or fuse? It is hard to check since all fuses look to be good.
Nov 30, 2015 at 8:04 AM
HMAC300
  • 48,601 POSTS
It sounds like the maxi fuse # 22, 70 amp needs to be checked for power. Here is a guide to help you get started:
Check out the diagrams (below). Please run some tests and get back to us.
Cheers
Nov 30, 2015 at 9:55 AM
BOOPERIII
Thanks for the guides and information, the fuse was blown! This site is great it worked. I am back on the road. :)
Jul 15, 2018 at 11:26 AM
CHRIS STILLWELL
I have a 2006 Honda Odyssey, I ran it for 10 minutes while cleaning ice off windows, then got in driver's seat placed vehicle in drive went to drive away, car wouldn't move, wouldn't even accelerate, few lights popped up on dash. So I turned ignition off then back on. Now I'm met with no power, no flashers either... I'm stumped
Jan 19, 2020 at 9:56 AM
Was the engine running do you have any check engine lights? if so here is a guide to help us get the codes:
Jan 20, 2020 at 10:17 AM
CHRIS STILLWELL
No power at all now, sent vehicle back to dealer... Hopefully nothing major.
Jan 20, 2020 at 11:03 AM
It sounds like a bad connection. here is a guide that can help:
Please let me know what they find.
Jan 20, 2020 at 11:18 AM
