No ECM signal from ECM to fuel pump relay
2004 CHEVROLET TRUCK
220,075 MILES • 6.6L • V8 • 2WD • AUTOMATIC
CHARLESHOPPER
This issue is on the truck listed above c4500 with 6.6l diesel engine in it. I am not receiving any signal from ECM when I turn to run/ start position. I am very stumped on this truck. Need help badly.
Apr 7, 2021 at 8:31 AM
CHARLESHOPPER
I need to know if you guys found anything on my problem on this 2004 c4500 with duramax diesel yet?
Apr 7, 2021 at 2:14 PM
Good afternoon,
I attached the wiring diagram for you below. Check the ECM connector 2 pin 9 for power with the key on. It will only have power for 2 seconds with the key on. It should have constant voltage while cranking. If there is no voltage the ECM is the issue.
I attached the procedure replacing the ECM and the programming as well.
Apr 7, 2021 at 4:01 PM
