Vehicle listed above 90ps, with dual mass flywheel.
I recovered this van a few nights back after the owner lost pedal pressure.
Slave had blown its rubber around plunger hence fluid everywhere.
The new slave and clutch fitted also changed master due to its age but goes into gear but clutch right out and nothing doesn't move.
I even tried the old clutch after cleaning it but it's just the same.
I originally thought it may be the release bearing but it goes into gear.
I haven't tried to see if it will go in gear without the pedal being pressed but will do in a short while.
Any suggestions (please help)
Regards
Brian
If i can just add that i am a time-served techie with 37 years' experience.
Regards
Brian
Feb 14, 2022 at 6:48 AM
