message. My scanner works on all my other vehicles, (except my 1991 Bronco-that needs it's own scanner).
I changed the dashboard completely about 3 years ago because they all fail in Dodge trucks but I also had other issues with the HVAC that I won't go into except to say that the previous owner did a real hack job on an attempted repair of the heater core and blend door actuator. They cut the shell in half at the bottom and tried to reassemble everything with foil tape. Didn't realize any of this until after buying it. Just wondering if I missed a wire, connector.. Can't remember if I ever scanned it before replacing dash. Haynes Manual shows diagram that says pin 45 is data transmission, pin 46 is data rec. I'm guessing that the PCM is receiving data as all the idiot lights go on in key on mode and I have a check engine light on-just no communication to obd port. Should there be voltage signal on that terminal at the port? If so, how much and which terminal at the port would be the one to get the data for the scanner at the obd connection?
Sep 2, 2019 at 12:05 PM
