Hello, I am so close to giving up. I got this car from a friend of mine. The mechanic said it was the ECU and had it replaced. When he went to the dealer they reprogrammed the new one and said it would not start because the battery was bad. My friend released the keys and it started and drove back home but once he shut it off it would not start again. Everything comes on like it is going to start. I got a new battery but it only clicks once when I try to start it. All lights come on except the check engine light. I hooked up a scanner thing from Wal-Mart(cheapo) and it says no communication with ECU/PCM but says compression good and N/A on almost everything else. I think it may have worked for a minute but my be touched the fuse box under the hood and it says lost communication now. The check engine light still never showed before but the OBD tool connected to it at least. Please what could it be? Also, the airbag symbol flashes a few times when I turn the key and power steering message displays. Sara
Nov 22, 2018 at 6:26 AM
