Battery good. car will not start. no noise at all when key turned on. No clinks, nothing.
dash and brake lights work. Key turns in cylinder.
when ignition wires jumped near ignition switch, car starts and runs but shuts right off..
I did not try a new ignition switch..does the car key have to be in on position when jumping the ignition wires to continue to run? Or should it keep running once you jump ignition wires..
I don't know what colored wires were jumped. can't reach starter relay way up under dash in row 3.
Any help appreciated. i want to put a new ignition switch (electrical side only) not cylinder. And then hook up ignition switch (electrical side) terminal plug to new ignition switch, then try to start with screwdriver.
Aug 17, 2019 at 5:48 PM
