Shift to park message accessories stay on won't shut off. when try to push start button goes black and service engine light stays on only and then after about 10 seconds call dash lights kick back on just like when you start the car. also noticed shift indicator light is gone so I have no park, drive, neutral indicator on dash. put in brand-new battery check wires some battery looking for brakes or corrosion everything tested good. so every day after trying to figure it out have to disconnect battery so battery doesn't die from accessories being on. every once in awhile when I first reconnect battery after battery has been disconnected all night the park indicator will appear where it's supposed to be in message center and the car will start. that only happened twice. it's been awhile since it happened. so I noticed when park indicator is present the car will start, but where did it go? I went to AutoZone because someone told me it could be a shift indicator, but they have no listing for it for my car and I can't even find where it is. is that the problem? and also I got a neutral safety switch. could that cause the problem? I did not put it in yet I'm waiting to see if that could cause it because it's inside the transmission.
Aug 3, 2019 at 3:57 PM
