Are you using a scan tool to set the timing? You can't set it correctly without one.
If you have a scan tool you will have to hold the engine at around 1100 rpm, then loosen distributor set the timing at 0 degree +-2 before TDC. Tighten the clamp and recheck with tool. The computer takes it from there. If you adjust it any other way it won't run properly.
As for the no start. HMAC is correct, those side terminals are one of the worst things out there. Any battery seepage goes into the connector and into the cable. They look OK but underneath they are trash.
May 15, 2017 at 12:06 PM
