no crank no start, it has been sitting few months?
2011 MAZDA CX-9
170,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
BAYNH
  • 6 POSTS
not getting ground signal from PCM to starter relay signal side, have power on load side, wiring diagram shows PCM sends ground and power to starter relay signal side. only getting power when in crank position. will crank when put test light to y/gr wire at PCM hooked to battery ground. Also, no comm at dlc.
Jun 25, 2025 at 4:03 PM
BAYNH
  • 6 POSTS
cars been sitting few months due to this issue, not much info on it, besides starter has been replaced, also extra PCM in back seat. also, prndl doesn't light up at cluster or at shifter. checked 5v ref at MAF that's good, disconnected batt negative checked can at dlc pin 6 and 14 only had 8.8. disconnected connector 3 at BCM then changed to 120ohms.want to make sure I didn't miss anything simple before replacing PCM or BCM.
Jun 25, 2025 at 4:13 PM
With the systems on I would check for power and the meter fuse on the right side of the dash, also check the "engine" and "Room" fuse at the left rear of the engine compartment. This guide can help:
The room fuse runs the BCM which supplies data to the data link connector. The fact that the prndl doesn't light up, it can be a bad TCM. This is going to take some testing, powers and grounds, we should try to get the data link connector working to help us. Please go over this video:
https://www.youtube.com/watch?v=6Tlg3JmgNSQ
Please go over these guides and get back to us.
Jun 26, 2025 at 10:24 AM
