not getting ground signal from PCM to starter relay signal side, have power on load side, wiring diagram shows PCM sends ground and power to starter relay signal side. only getting power when in crank position. will crank when put test light to y/gr wire at PCM hooked to battery ground. Also, no comm at dlc.
Jun 25, 2025 at 4:03 PM
