Bought this car out of an insurance auction and have been repairing damage to rear wheel. buy new key for a push button start it wont crank or turn over or anything. nothing from starter at all. check with multi-meter at signal wire on the start and i am not getting signal. So checked at fuse box and it will crank if i cross relay but when i check signal port on fuse box it only reads like two and a half volts. Is it supposed to be 12 volts? when pressing start button in car? What could cause a low signal? is it low? replaced push button also n new battery and no security light flashing when powering up. took start to O'Riellys and tested good. relays good. is there a ignition switch somewhere? all i could see without digging into the dash was the push button and the key-less start senses key. I do not know. any suggestions or advice appreciated.
May 29, 2019 at 8:01 PM
