No crank no start
2000 FORD EXPEDITION
300,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
BRANDON CONGER
  • 9 POSTS
I have replaced the starter solenoid. I have tried to jump it through the starter. it is getting power to it when I turn the key over all I get is a one click from the solenoid on the firewall. I do not know what else to do.
Jul 5, 2021 at 6:07 PM
First, make sure the battery terminals are clean and tight. If they are, then we need to check where power is lost.
First, see if it will start by placing it in neutral. If it does, then the neutral/park switch may be bad.
If that doesn't change anything, I need you to check fuse 111 in the battery junction box and fuse 21 in the central junction box. In addition to checking the fuses, confirm there is power to them. Note: Fuse 21 in the central junction box will only get power with the key in the start position, so you will need a helper to do this.
If the fuses check good, I need you to go to the s terminal on the starter. It will be the smaller gauge wire of the two. It should get power when the key is in the start position. If it does and you do have power to the starter direct from the battery (larger wire) the starter is bad.
I have attached the wiring schematics below for the starting system for your reference. I had to cut the schematic in two to make them readable, but I did overlap them so you could follow them.
Here is a link you may find helpful when testing the wiring:
Here is one more link you may find helpful when testing the starter for power:
https://www.2carpros.com/articles/starter-not-working-repair
See pics below Pics 3-4 are the fuses. Pic 3 is the underhood box and pic 4 is the central junction box in the vehicle.
Jul 5, 2021 at 9:31 PM
BRANDON CONGER
  • 9 POSTS
I did everything and found out it may be my starter solenoid the one that's attached to the starter it's not popping out.
Jul 6, 2021 at 9:39 PM
Sounds like you were busy. Do me a favor. Take a look at the attached pic below. Let me know which symptom you feel best describes what you experience. Then, I will get the specific tests you need.
See pic below.
Jul 6, 2021 at 10:16 PM
BRANDON CONGER
  • 9 POSTS
It will be the first one I took the starter off and it is spinning it just will not engage and there is only one click coming from the ceiling noyd on the firewall.
Jul 7, 2021 at 1:39 AM
Brandon,
When you say it spins but doesn't engage, it sounds like the bendix is bad. That is the part of the starter which engaged the starter motor gear to the engine flywheel to crank the engine.
When this happens, do you hear the starter motor spinning? Is it possible for you to record what is happening and upload it for me to hear?
Let me know. When I read through the list above, it seems the last thing mentioned is what fits what you are experiencing.
Jul 7, 2021 at 7:43 PM
BRANDON CONGER
  • 9 POSTS
Put put new starter solenoid on it fired up one time and then nothing just to click again.
Jul 10, 2021 at 5:56 PM
Is everything tight at the starter/solenoid? Do we have a solid power and ground from the battery to the solenoid?
It sounds like when you installed the new part, you moved something which allowed for contact to be made one time. See if you wiggle the wiring between the battery, solenoid, and starter if it changes.
Also, is the starter the original one or has it been replaced and where is the click coming from? Is it the starter or the solenoid?
Jul 10, 2021 at 9:02 PM
BRANDON CONGER
  • 9 POSTS
Everything is tight but my battery-saver relay it's clicking one time when I go to try to start the vehicle. I think I might have a short in my cables from the battery to the car. so I'm going to run new cables now.
Jul 12, 2021 at 10:49 AM
Brandon, let me know if that takes care of it.
Jul 12, 2021 at 8:29 PM
BRANDON CONGER
  • 9 POSTS
That did not work for a new cables and still doing the same thing. my battery saver relay keeps clicking when I turn the key on and off and when I took it out it was hot.
Jul 15, 2021 at 2:03 PM
If it is getting hot, it sounds like it isn't timing out. Do me a favor. Take a look at the diagnostics below and let me know if you are comfortable performing them. Something is causing that to get hot and I have a feeling if we determine what it is, the other problems will resolve themselves.
Jul 15, 2021 at 9:04 PM
BRANDON CONGER
  • 9 POSTS
How would I test it can? I get a youtube link on how to do it?
Jul 16, 2021 at 2:58 AM
I'm not sure I understand. Are you asking how to test the CAN bus or the battery saver? The battery saver directions are above. If you want to test the can-bus, you simply need a scan tool that can read the system.
Here is a video showing it being done:
https://youtu.be/InIlnsjOVFA
Jul 16, 2021 at 6:52 PM
