No crank no start
2012 FORD FUSION
54,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
COLERITER
In my car it was in a collision in the airbags were deployed. the radiator in the bumper was the only thing that was damaged. I am having a problem with it being locked in anti-theft mode, but the key turns and everything I’ve got it to crank twice but it was very short cranks. it will not crank and start. And I am not getting communication from my OBD to scanner. I am getting power that is it I have checked every single fuse and all of them are good.
Feb 29, 2020 at 9:05 PM
SCGRANTURISMO
  • 4,897 POSTS
This could be a case where you just need to reset your vehicle's inertia fuel cutoff switch. It should have a button on top that you just need to push down. This switch is set to open on an impact to shut off the fuel pump in case of a bad accident to keep your car from exploding. In the diagrams down below I have included a diagram of the inertia fuel cutoff switch's location which is behind the passenger side kick plate. Please get back to us with how everything turns out.
Thanks,
Alex
2CarPros
Feb 29, 2020 at 10:29 PM
