car will not crank using ignition key.
fuses check good.
upper and lower crank sensors replaced.
battery checks good.
fuses under rear seat check good.
car will start if shorted out starter relay then shuts off immediately.
when key is turned display panel goes black.
tried both keys, no help.
Security light goes out after doors are closed, and ignition turned to the on position. I am looking now at the neutral safety switch and will check that.
All I can say now is help?
Car is an STS.
fuses check good.
Car is an STS.
Jul 6, 2019 at 6:45 PM
