No crank, no start
2004 HONDA ODYSSEY
1,560,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
YANNICRISANTOS
  • 132 POSTS
I am having issues with the van I bought. it started with me having to turn the key over a couple of times unit it finally cranked. Sometimes it crank and started working with out a problems. And sometimes it will not crank at all. No click or anything. Had battery, and starter tested.
Mar 11, 2018 at 5:44 PM
Even though you have the starter tested it still could be the starter. It could have a bad spot which only shows up every once and a while. When the engine wont crank use a test light to check for power at the small trigger wire.
Check toward the bottom of this guide to show you how. I say this because Honda has a problem with their starters working and then not.
This guide will give you an idea on how to change it out.
Mar 13, 2018 at 11:30 AM
