Turn the key to start, dash lights come on, only sound is relays clicking. Security light comes on for 5 seconds and then goes off. It isn't flashing. I have installed a new ignition switch, fuel pump, Crankshaft Position Sensor. Checked all relays and fuses. I used a cheap scanner that said Crank Sensor needs Relearn code. The security light was flashing earlier, so I tried the 30-minute process of switch turn to crank release back to on position wait, Security light is supposed to blink ten minutes, then go off. Do two more times as the first and start up. When I turn the key to start the car and release back to on, it doesn't start. Now I try again but the light comes on for 5 seconds then goes off so I can't do the security relearn. If I turn the key to the on position, pour gas in throttle body and jump across starter hot terminal and purple solenoid wire; car cranks up and runs a few seconds. Injectors are getting fire to one side but no pulse to the other side. Help please?
Nov 18, 2022 at 6:28 PM
