I bought the van listed above and I was told that it only needed a starter. The car would not crank at all, so I put a new starter in it, still same symptom, jumped the starter with ignition open and no spark. Bought a new ECM and the car started right up and ran for about 30- 45 minutes. Until I shut it down to restart and make sure that it would be alright. The van started up but shut off after 10-15 seconds. As I kept trying to restart, it went right back to no crank mode. I believe that maybe a crankshaft position sensor or cam sensor is probably shorting out the ECM. I noticed that when I unplug the negative battery terminal, or attempt to reconnect the negative terminal, I get a light ark or light spark. Is it possible that it could be maybe one of these sensors? Anyone?
Any help would really be appreciated!
Thank you,
ED
Thank you,
ED
Apr 1, 2020 at 6:22 PM
