Hey everyone ,
Wanted the groups advice on a problem with my vehicle listed above XS.
So this started a few months back, basically I was idling, and the car started shaking and was idling very rough, few seconds after the SES light started flashing to which I promptly shut off the car to have it diagnosed. The OBD scanner showed misfire on cylinder 5, I changed out the spark plug and boot and the problem went away.. fast forward another month and the same thing happens (again at Idle) and I knew it was a misfire , checked it and cylinder 5. So this time I changed out the coil pack.. car drives fine now a few weeks later it does the same thing and SES light comes (same symptoms as misfire) on but this time the car shut off instantly. Now even if I try turning it on , it won’t crank. All the electronics are working and I can hear the fans turn on as well when it goes into the on position but no crank.
The weirdest part is now the OBD scanner says it cannot read the vehicle and won’t get a proper reading. Any ideas ? I’m pretty lost at this point.
May 17, 2020 at 12:12 AM
