It started up fine when bought but found out that there were wires running from the fans to the ECU fuse. when removed it wouldn't start. it also had an ECU code before it wouldn't start. I was thinking it was the ECU by passing the alarm system to start. I also replaced wiring harness from fuse box to ECU and engine components.
Feb 27, 2021 at 1:09 PM
