When you have a crank so start condition, most times it is either a fuel or ignition spark-related issue. Here is what I need you to do.
See if it starts with starting fluid. If it does and then stalls, we know it's a fuel-related issue. If there is no change, I need you to check for ignition spark to the plugs.
Here is a link that explains how that is done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Try this and let me know the results. Note: If you have both spark and fuel, record the engine cranking and upload it for me to hear. I may be able to recognize the problem.
Jul 25, 2023 at 10:01 PM
