No coolant intake
1995 SAAB 900
SUZANNEC
  • 5 POSTS
The "coolant level low" warning light come on my display. The car is using no coolant. I had someone flush the coolant system and replace the thermostat. He told me that if that didn't work it probably is the water pump. Could it be a sensor.. ?
Thanks
May 20, 2013 at 2:38 PM
MHPAUTOS
  • 31,937 POSTS
I would say that the low coolant sensor is stuck, check this out first.
May 21, 2013 at 4:15 AM
SUZANNEC
  • 5 POSTS
Thank you. How do I go about testing it for being stuck? Is it obvious once it is pulled out? Push on parts to check if they are sliding or not? I'm not a mechanic. I'm a mom between jobs and have to save all the money I don't have ; ) Thanks again,
Suzanne
May 21, 2013 at 12:11 PM
MHPAUTOS
  • 31,937 POSTS
You would have to remove the sensor and test it, it may be a level type or an electrical immersion type that relies on being in coolant to keep the light off, you will have to pull it It and inspect it.
May 21, 2013 at 2:23 PM
SUZANNEC
  • 5 POSTS
Thanks. I am going to pull it. The fluid/coolant level is where it is supposed to be. I've noticed "algae" build up. Should I try to clean it out with a wire/baby bottle brush before adding new fluid or get a whole new coolant reservoir? I can pull it and clean it The coolant has been at a consistent level or a LONG TIME.
May 21, 2013 at 3:53 PM
MHPAUTOS
  • 31,937 POSTS
To be honest, i have never done one on your model, i will see if i can find out how it is removed, will proberbly be screwed in.
May 22, 2013 at 4:13 AM
SUZANNEC
  • 5 POSTS
Thanks. I pulled the part and it does not enter the coolant reservoir. It is a white rectangular piece flush up against the side of the reservoir.
May 26, 2013 at 2:21 PM
SUZANNEC
  • 5 POSTS
Thanks for your help. I think I got it! I took out the part that the sensor plugs into that is flush against the coolant reservoir. I cleaned it up. Then checked for amp. on the sensor itself. It had elec. going to it. Put it all back together. Prayed! The "Coolant Level Low" sign did not come on. The car's display says "Checking" when I first start it. The CLL light would always come on. It didn't, even after taking for a spin around the hood for a bit!! YAY!!!! Thanks again,
Suzanne
May 26, 2013 at 4:14 PM
MHPAUTOS
  • 31,937 POSTS
Good to hear thast you fix it, well done.
May 27, 2013 at 2:37 AM
