Not for sure why I’m not getting compression in cylinder three.
I’ve done compression test and got zero compression! Other cylinders have compression. Leak down test was unsuccessful, I couldn’t hear anything in the intake or exhaust. Smoke test wasn’t too good because I couldn’t block off intake too good. I poured marvel mystery oil in the intake hoping it would clear all the carbon build up and possibly free up the rings if that was the issue, but did run a little better.
What are your thoughts? My next option is to get a bottle of Bars Leaks Gasket Sealant and see what that does just in case.
Apr 20, 2020 at 8:40 PM
