Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Subaru
Legacy
Engine
Symptoms
Compression
No compression on any cylinders
2005 SUBARU LEGACY
100,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
RUBEN13
MEMBER
FOLLOW
I replaced the timing belt because the old one broken.There were no bent valves. Car turns over there is power, fuel, and spark.
Nov 30, 2018 at 10:40 AM
CERTIFIED EXPERT
Good afternoon,
How did you determine there were no bent valves?
If you have no compression it is either the belt is not on correctly or there is valve damage.
https://www.2carpros.com/articles/the-reasons-for-low-compression
Are the marks lined up correctly as in the attachment I attached?
Image (Click to enlarge)
Nov 30, 2018 at 11:26 AM
RUBEN13
MEMBER
Yes, all the marks are lined up correctly.
Nov 30, 2018 at 12:02 PM
CERTIFIED EXPERT
Again, how did you determine there was no valve damage?
All indications are that you have valve damage.
The heads will have to come off and the valves inspected.
https://www.2carpros.com/articles/how-a-cylinder-head-works
Nov 30, 2018 at 12:05 PM
