Following an issue of a clogged muffler, and then cutting the muffler off, I performed a dry compression test. I found out I have no compression in cylinders 7 and 8 and all the other cylinders have approximately 140 psi (on a cold test). I then did a wet test on the two in question with no change in the results. What could be the most likely problem? the truck will not start and it backfires through the TBI. I have since tried blowing into it with compressed air and can hear a hissing sound when I open the throttle.
Oct 12, 2019 at 11:56 AM
