Recently I had a check engine code, and code reader said # 3-cylinder misfire. I changed the plugs and coils, and it still came up with a code, although then it said "multiple cylinder misfire". So, I took it to my local mechanic, and he determined that #5 cylinder had no compression. So, now I am faced with something that could possibly be a burned valve, broken valve spring, failed head gasket etc., in the cylinder head, to something that could be more catastrophic like particles being sucked into the engine because of "catalytic converters being damaged due to multiple engine misfires."(Which the mechanic also determined at the shop.)
I don't know how bad they are, when I asked him, he said he didn't know. So, at a minimum I am looking at replacing the cats and cylinder heads being redone. (Assuming that is the problem is in the heads and I have no damage to the block). I guess my main question is, how much could my repair bill be if it is in the head(s), and replacing the cats?
Jan 24, 2024 at 2:23 PM
