The inlet manifold on cylinder three the bolt had broken off and caused the bolt to fall into the engine where the piston is. The car was not driven as it was parked when I heard the noise and was not driven at all. There was no damage done as this was fully checked. However, it did leave a mark on the piston at the top only. After putting it back together one of cylinders number three had no compression.
Basically my question is cylinder three only has no compression what could this be?
Jul 1, 2018 at 4:43 PM
