Seems to be stuck in gear not sure but seems like second or third and the check engine light is on?
2009 MERCEDES BENZ C350
87,000 MILES • 3.5L • 4 CYL • 2WD • AUTOMATIC
MCHAWLEY42
  • 5 POSTS
Also the dash display which normally shows PRND and C (which I believe is for cruise and sport option) only shows PRND and the C seem to have disappeared.
But initially when it happens I switch the engine off and restart it which seems to solve the problem for a while but the problem is now constant also now when I put it in D or R there is a little thump.
No-communication with transmission control module
Oct 21, 2019 at 2:26 AM
Is that the code? No-communication with transmission control module What is the number please? Lets begin by checking the fuses. Here is a guide to show you how and the fuse locations and definitions for your car below:
Here are all fuse and relay locations for your car please check the fuses with the key on. Check out the diagrams (below). Please let us know what you find. We are interested to see what it is.
Oct 22, 2019 at 4:09 PM
MCHAWLEY42
  • 5 POSTS
The error code is Event 1405.
Oct 23, 2019 at 12:10 PM
Did you check the fuses are they okay? Also I assume the code is a P code? Which is an EGR problem which doesn't make sense. Is this a Euro Car?
Oct 24, 2019 at 9:46 AM
MCHAWLEY42
  • 5 POSTS
Yes I check the fuses. It’s a German.
Oct 24, 2019 at 9:52 AM
MCHAWLEY42
  • 5 POSTS
1405 communication with control unit transmisssion has a problem.
U010087 Communication with engine control unit has malfunction
Oct 24, 2019 at 9:55 AM
MCHAWLEY42
  • 5 POSTS
Road tested vehicle, found vehicle slams into gear when selector is moved into forward or reverse ranges, and transmission does not shift. Performed quick test, no faults found in ME, found only event 1405 no CAN message received from transmission control unit. Transmission control unit is not showing up on quick test, ABR also showing no CAN message received from engine control module or electronic transmission control unit (event 6106). Tries to access transmission control unit. Communication not possible.
Oct 24, 2019 at 10:03 AM
Fuse #33 10 amp (front SAM control) check with the key on does it have power?
Oct 24, 2019 at 11:46 AM
