No communication to scan tools
2010 CHEVROLET AVEO
94,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
LYKINS6
  • 4 POSTS
No crank, no start unless you take the positive and negative battery cables and hold them together for a couple minutes, then it will start. And also the hold light will flash. When it does start it runs good, but the hold light will flash and the check engine will be on. I have checked all of the fuses they are all good.
Jun 14, 2019 at 10:32 AM
Good afternoon,
Let us start with the code for the check engine light?
What is the code that was set?
Jun 14, 2019 at 1:35 PM
LYKINS6
  • 4 POSTS
No communication with solus or with a actron scanner. All fuses are good.
Jun 15, 2019 at 9:06 PM
What kind of scan tool.
Jun 15, 2019 at 10:18 PM
LYKINS6
  • 4 POSTS
Snap on solus or the actron generic scanner.
Jun 16, 2019 at 9:16 AM
Does it work on any other vehicle?
Jun 16, 2019 at 1:51 PM
LYKINS6
  • 4 POSTS
Yes the solus works on other vehicles. The problem is the PCM and the customer is not going to fix the car.
Jun 18, 2019 at 11:51 AM
Just to be sure, check pins 6 and 14 on the 16 pin connector for resistance and let me know that figure.
Jun 18, 2019 at 11:56 AM
