No cold air on driver side
2005 HONDA ODYSSEY
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
KIRAN DUNTHULURI
I have done a AC test by holding auto and then off buttons. It shows code I "an open in air mix controller motor circuit. I checked the motor and it is moving when changing the temperature. Do I have to replace the unit to fix the issue?
Jul 15, 2017 at 7:25 AM
There is another blend door actuator that handles the side to side temperature.
Here is a guide that will show you what you are in for when doing the job also some diagrams (below) on how it is done on your car.
Jul 17, 2017 at 11:21 AM
