No code on check engine light
2000 MAZDA 323
96,300 MILES • 1.5L • 4 CYL • 2WD • MANUAL
DANIEL ERNST JONSEN
  • 21 POSTS
First and foremost the car;
European model 323 BJ (sedan) glx 1.5i ((ZL-DE) think Protegé lx in body and model equipment), but with a mid 90's obd1 system like the American 626's of the time, and equivalent error codes.
Now, the issue at hand:
Cold start, my CEL (check engine light) comes on when i start the engine, and disappears by itself after less than a minute.
With your guide on how to get Mazda OBDI codes, i have NOT succeeded, as the check engine light only appears with the engine running, not just with the key turned to ignition.
Not sure if it was a coincidence, but i had a very rough idle with the engine running, and OBDI pins "TEN" and "GND" connected (less than 100 rpm's on the needle, but didn't choke - engine does in the area of 600 rpm's in idle when warm, 1,500 rpm's cold.
I can provoke the check engine light to appear, by turning my steering wheel to either side - getting a little resistance is usually enough to make it appear, and removing said resistance makes the check engine light disappear again.
No success on getting a code that way either, i tried.
https://youtu.be/CmESR8lMvBk to give you a better idea of it.
Check engine light appears and disappears at a standstill when provoked, as well as slow driving around corners, and roundabouts when rpm is in the lower range (though not always, and not always a constant either).
Feb 11, 2020 at 1:56 AM
SCGRANTURISMO
  • 4,897 POSTS
Are you sure it's an OBD 1 system? In the United States law for all vehicle's to be OBD 2 compliant was 1996. If it is an OBD2 system it would have a 16 pin Data Link Connector[DLC]. I have included a diagram of what it would look like with a pin out chart in the diagrams down below.
Thanks,
Alex
2CarPros
Feb 11, 2020 at 3:09 PM
DANIEL ERNST JONSEN
  • 21 POSTS
Hello Alex
Yes, until end of production the European 323's didn't change to OBDII.
Not sure if it's due to import or not.
Feb 11, 2020 at 4:39 PM
SCGRANTURISMO
  • 4,897 POSTS
So it looks like you are going to have to get a OBD 1 code reader. I tried to find the instructions for pulling codes from a 1995 Mazda Protege with a 1.5L engine, and this is what I got in the diagrams down below.
Thanks,
Alex
2CarPros
Feb 11, 2020 at 11:25 PM
DANIEL ERNST JONSEN
  • 21 POSTS
Hello Alex,
It would seem to be the case - do you think an OBDI to OBDII adapter (i own one for some reason) will be sufficient for a live data pull?
Got a certified Mazda mechanic in my area, but he's charging the equivalent of $90.00 for diagnostics, without guarantees he can even pull the error code out.
Feb 12, 2020 at 5:12 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Sure, why not. As long as you have the correct adapter. In the diagrams down below I have included the list of P and U codes that the OBD 1 system will store in the Powertrain Control Module[PCM] if there is a problem. Please report back with how everything turns out and I hope that this helps.
Thanks,
Alex
2CarPros
Feb 12, 2020 at 5:40 AM
