Okay, I was driving truck going through the gears as I got up a hill got to the top of hill went to put it in fifth gear wouldn't go in gear, then realized had no clutch pressure. Got the truck home and immediately got to work on taking slave and master cylinder out slave cylinder was shot rod fell out when it was pulled out of transmission. Master cylinder looked good rod was still tight but had it out so replaced it anyways. With new cylinders in still have no pressure. I have bleed the line several times and could get air out bleeding it from the slave cylinder but still wont build pressure. no leaks in lines. everything is new. someone please help need my truck back ASAP.
Aug 14, 2019 at 6:25 AM
